zener
3 years agoHow to generate the niosv_g in batch?
In a continuous integration flow I usually check in only the "*.ip" files in git and then build the files for synthesis and simulation on demand using qsys-generate. When I do this for NIOS-V I get ...
- 3 years ago
My last problem was resolved when I obtained a "M" core license as well. It seems like Quartus will not generate a sof file unless a license for both "M" and "G" core are installed, even when instantiating a single "G" core only.
EBERLAZARE_I_Intel
3 years agoHi,
Which Quartus version are you using Pro or Standard?
