21 years agohow to change files to excutable mode?
when i input in uclinux shell :
chmod 777 myfile the shell say: myfile: Read-Only system well, how to change file mode? thanks !4 Replies
Check to see what type of file system this file is on? My bet is you're trying to change permissions on a romfs (read-only) filesystem or some other "read only" filesystem.
Cheers, - slacker - Altera_Forum
yes ,it is romfs, but do you know how to change the permission of files in such system or nios IDE? thanks
Read only is read only is read only. There is no way to change the permissions to write to a romfs filesystem. By definition, it is impossible.
You need to read up on the available filesystems (perhaps, ramfs, jffs -- on flash, etc.), implement one of those filesystems. If you're asking how to _change_ a particular file on a romfs filesystem, that is covered in the Microtronix-provided documentation. Start reading. :-) Cheers, - slacker - Altera_Forum
Hi sunclever,
> do you know how to change the permission of files in such system or nios IDE? I went through this some time ago before switching to cramfs/jffs2, so the following is subject to memory loss ;-) ... I believe all you need to do is give your file an 'exe' extension. When the romfs is created via the IDE, the exe extension is removed and the execute attribute should be set. Regards, --Scott
