21 years agohow to change files to excutable mode?
when i input in uclinux shell : chmod 777 myfile the shell say: myfile: Read-Only system well, how to change file mode? thanks !
21 years agoHi sunclever,
> do you know how to change the permission of files in such system or nios IDE? I went through this some time ago before switching to cramfs/jffs2, so the following is subject to memory loss ;-) ... I believe all you need to do is give your file an 'exe' extension. When the romfs is created via the IDE, the exe extension is removed and the execute attribute should be set. Regards, --Scott
