Chris039
3 years agoHow to calculate the time for running the code in Nios II and Nios V?
How do I calculate the time used for executing a command in Nios II and Nios V.
I was using the example in the below link but the results from Nios II and Nios V are different.
https://cp...
ShengN_altera
3 years agoHi @Chris039 ,
I tested the MAX 10 Nios II Hello World example in Intel FPGA Design Store. I found out for Nios II Interval Timer needs to be added in order to get accurate and valid execution time calculation. Also in BSP Editor, set the sys_clk_timer check image below:
The execution time of Nios II for running code without looper is 1427 clicks which is close to Nios V execution time of 997 clicks.
Folder attached below.
Sheng
