Chris039
3 years agoHow to calculate the time for running the code in Nios II and Nios V?
How do I calculate the time used for executing a command in Nios II and Nios V.
I was using the example in the below link but the results from Nios II and Nios V are different.
https://cp...
ShengN_altera
3 years agoHi @Chris039 ,
Do you have any further update or concern?
Let me know if there's any.
Sheng
- Chris0393 years ago
Hi Sheng,
I tried running the second code that you have shared.
clock_t t;t = clock();
printf ("Calculating...\n");usleep(1000000);
printf ("Bye world...\n");
t = clock() - t;printf ("It took me %ld clicks (%f seconds).\n",t,((float)t)/1000000);
printf ("It took me %u clicks (%x seconds).\n",t,((float)t)/1000000);
Why is my value in the bracket has negative sign and different from yours?- Chris0393 years ago
If I would like to delay one second in the code? what is the value I should put in usleep ()?
