13 years ago
how could i get two tse mac with two phys on DE2-115?
i tried to use both of the phys on DE2-115, so i add two mac, two sgdma_rx, two sgdma_tx, two descriptor_mem, and one cpu in Qsys.
and i changed the top level file, in order to use both of the phys.
then build a "simple socket server" project, but changed nothing.
it turned out as follows:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
Static IP Address is 192.168.1.2
prep_tse_mac 1
Your Ethernet MAC address is 00:07:ed:ff:cd:15
prepped 2 interfaces, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x08223400
INFO : PHY Marvell 88E1111 found at PHY address 0x10 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x01000000
neither PHY can ping through...T_T
then i add this code into "int main (int argc, char* argv[], char* envp[]){}" in "iniche_init.c" file:
alt_tse_system_mac psys_mac_0 = {TSE_SYSTEM_MAC(TSE_MAC_0)};
alt_tse_system_sgdma psys_sgdma_0 = {TSE_SYSTEM_SGDMA(SGDMA_TX_0, SGDMA_RX_0)};
alt_tse_system_desc_mem psys_mem_0 = {TSE_SYSTEM_DESC_MEM(DESCRIPTOR_MEMORY_0)};
alt_tse_system_shared_fifo psys_sfifo = {TSE_SYSTEM_NO_SHARED_FIFO()};
alt_tse_system_phy psys_phy_0 = {TSE_SYSTEM_PHY(1, NULL)};
alt_tse_system_mac psys_mac_1 = {TSE_SYSTEM_MAC(TSE_MAC_1)};
alt_tse_system_sgdma psys_sgdma_1 = {TSE_SYSTEM_SGDMA(SGDMA_TX_1, SGDMA_RX_1)};
alt_tse_system_desc_mem psys_mem_1 = {TSE_SYSTEM_DESC_MEM(DESCRIPTOR_MEMORY_1)};
alt_tse_system_phy psys_phy_1 = {TSE_SYSTEM_PHY(1, NULL)};
alt_tse_system_add_sys(&psys_mac_0, &psys_sgdma_0, &psys_mem_0, &psys_sfifo, &psys_phy_0 );
alt_tse_system_add_sys(&psys_mac_1, &psys_sgdma_1, &psys_mem_1, &psys_sfifo, &psys_phy_0 );
it reports as follows:
prep_tse_mac 1
[tse_mac_init]
OK, x=4, CMD_CONFIG=0x01000000
MAC post-initialization: CMD_CONFIG=0x05000203
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of : 192.168.1.2
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
still neither one can ping !!!T_T
then i add
"TSE_SYSTEM_EXT_MEM_NO_SHARED_FIFO(TSE_MAC_1, 0, SGDMA_TX_1, SGDMA_RX_1, TSE_PHY_AUTO_ADDRESS, 0, DESCRIPTOR_MEMORY_1)"
into "alt_tse_system_info tse_mac_device[MAXNETS] = {}" at "tse_my_system.c" file
report below:
prep_tse_mac 0
prep_tse_mac 1
[tse_mac_init]
INFO : TSE MAC 1 found at address 0x08223000
INFO : PHY Marvell 88E1111 found at PHY address 0x11 of MAC Group[1]
INFO : PHY[1.0] - Automatically mapped to tse_mac_device[1]
INFO : PHY[1.0] - Restart Auto-Negotiation, checking PHY link...
WARNING : PHY[1.0] - Auto-Negotiation FAILED
MARVELL : Enabling auto crossover
MARVELL : PHY reset
INFO : PHY[1.0] - Checking link...
INFO : PHY[1.0] - Link not yet established, restart auto-negotiation...
WARNING : PHY[1.0] - Link could not established
WARNING : PHY[1.0] - Auto-Negotiation not completed! Speed = 100, Duplex = Full
[tse_mac_init]
OK, x=12, CMD_CONFIG=0x01000000
mctest init called
IP address of et1 : 192.168.1.2
NOW the ETHERNET1 can ping, it works well, but the ETHERNET0 still couldnt not!
could anyone help me!
i'm a beginner of nios II.
thanks a lot!
    now i find that:
    void alt_sys_init( void )
    ALTERA_AVALON_TIMER_INIT ( TIMER, timer);
    ALTERA_AVALON_CFI_FLASH_INIT ( CFI_FLASH, cfi_flash);
    ALTERA_AVALON_JTAG_UART_INIT ( JTAG_UART, jtag_uart);
    ALTERA_AVALON_LCD_16207_INIT ( LCD, lcd);
    ALTERA_AVALON_SGDMA_INIT ( SGDMA_RX_0, sgdma_rx_0);
    ALTERA_AVALON_SGDMA_INIT ( SGDMA_RX_1, sgdma_rx_1);
    ALTERA_AVALON_SGDMA_INIT ( SGDMA_TX_0, sgdma_tx_0);
    ALTERA_AVALON_SGDMA_INIT ( SGDMA_TX_1, sgdma_tx_1);
    ALTERA_AVALON_SYSID_QSYS_INIT ( SYSID, sysid);
    ALTERA_AVALON_UART_INIT ( RS232, rs232);
    TRIPLE_SPEED_ETHERNET_INIT ( TSE_MAC_0, tse_mac_0); <----- here
    TRIPLE_SPEED_ETHERNET_INIT ( TSE_MAC_1, tse_mac_1); <----- here
    only the last one get used, if change the turn TSE_MAC_1 before TSE_MAC_0,
    i.e.
    the "TSE_MAC_0" is avaliable.
    please help me~
    thx!
    I still working on it. Does it have some connection on the revision of Eclipse?
    i use the Eclipse 13.0,
    anything will be helpful~
    thx~
    FangQJ
