22 years agoHow can i burn my *.flash file into the flash
I have a *.flash file,now,I want to burn it into the flash at the address of 0x100000 . I use the nios2-flash programmer,the command line is :
nios2-flash-programmer --base=0x100000 --input=altera_nios_dev_board_cyclone_1c20.sof --input=filesys.flash but the output is: Aug 6, 2004 10:55:36 AM - (??) nios2-flash-programmer: Launching Quartus Progr mer to download: altera_nios_dev_board_cyclone_1c20.sof Aug 6, 2004 10:55:52 AM - (??) nios2-flash-programmer: Error opening target ha ware Aug 6, 2004 10:55:52 AM - (??) nios2-flash-programmer: Unable to open flash evice after successfully communicating with target. It is likely that you are using a flash-programming FPGA design which was not created for your target board. In order to program flash, you must first create a purpose-built flash-programming design (i.e. FPGA configuration) and associate it with your particular board. The Nios development kit is delivered with purpose-b lt flash-programming designs pre-built for several development boards. If you sh to program flash on your own board, you must first create a flash-programmin design. The process of creating a flash-programming design for your board is mostly automated. From a bash-shell, execute this script: mk_target_board --help what's wrong with me?2 Replies
You took the same trap as i did..
You have to specify the destination address in the flash while converting from .sof to .flash with "sof2flash --input=x.sof --output=x.flash --base=0x100000" (or whatever) At the flash-programmer you have to specify the address where the programmer can find your flash device . This is 0x800000 on the standard altera nios2 dev boards. I don't know for nios1 designs, but if you open them in sopc-builder you can extract this value.... nios2_flash_programmer --input=x.flash --sof=altera_nios_dev_board_cyclone_1c20.sof --base=0x800000 i hope this helps... - Altera_Forum
Thank you very much! I have resloved my problem. Best wishes to you!
