22 years agoHow can i burn my *.flash file into the flash
I have a *.flash file,now,I want to burn it into the flash at the address of 0x100000 . I use the nios2-flash programmer,the command line is : nios2-flash-programmer --base=0x100000 --input=altera...
22 years agoYou took the same trap as i did..
You have to specify the destination address in the flash while converting from .sof to .flash with "sof2flash --input=x.sof --output=x.flash --base=0x100000" (or whatever) At the flash-programmer you have to specify the address where the programmer can find your flash device . This is 0x800000 on the standard altera nios2 dev boards. I don't know for nios1 designs, but if you open them in sopc-builder you can extract this value.... nios2_flash_programmer --input=x.flash --sof=altera_nios_dev_board_cyclone_1c20.sof --base=0x800000 i hope this helps...
