14 years ago
Help:DE4 can't run simple socket server normally
I make a qsys hardware for DE4 board,and intend to run a simple socket server
but always failed.
attach my qsys file and information for run simple socket server.
# ########run information in nios ii 11.1
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Your Ethernet MAC address is 00:07:ed:ff:ed:15
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x05000000
INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PCS[0.0] - Configuring PCS operating mode
INFO : PCS[0.0] - PCS SGMII mode enabled
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000203
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 0.0.0.0
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
DHCP timed out, going back to default IP address(es)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
    Hi Tomlih,
    I am having similar problem like yours.
    Got the link established as shown. Somehow, it couldn't get the IP address. I am also using DHCP server to acquire the IP addres.
    Could you please share what's your problem that could lead to this issue?
    prep_tse_mac 0
    Your Ethernet MAC address is 00:07:ed:ff:6b:c7
    [tse_mac_init]
    INFO : TSE MAC 0 found at address 0x08003000
    MARVELL : Mode changed to RGMII/Modified MII to Copper mode
    MARVELL : Enable RGMII Timing Control
    MARVELL : PHY reset
    INFO : PHY[0.0] - Link not yet established, restart auto-negotiation...
    mctest init called
    -Carid
