14 years agoHelp:DE4 can't run simple socket server normally
I make a qsys hardware for DE4 board,and intend to run a simple socket server but always failed. attach my qsys file and information for run simple socket server. # ########run inf...
14 years agoHi Tomlih,
I am having similar problem like yours. Got the link established as shown. Somehow, it couldn't get the IP address. I am also using DHCP server to acquire the IP addres. Could you please share what's your problem that could lead to this issue? Thanks. InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Your Ethernet MAC address is 00:07:ed:ff:6b:c7 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x08003000 INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED MARVELL : Mode changed to RGMII/Modified MII to Copper mode MARVELL : Enable RGMII Timing Control MARVELL : PHY reset INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link not yet established, restart auto-negotiation... INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 0.0.0.0 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) DHCP timed out, going back to default IP address(es) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) Thanks, -Carid
