22 years agoHelp with us delay routine in C
Hi...I am trying to create an i2c engine in Nios to read and write to an external seeprom. The problem I am having is developing an accurate micro second delay routine for the protocol. I know the nr_delay function is for milliseconds and I'm not even sure of the accuracy of that function. I'm still a little new to C programming. One quick and dirty approach is the use of nop commands in a loop, but I don't know if the asm nop command timing is based off of my 48MHz clock coming into the chip or some predefined time. Does anyone know? Can anyone suggest something to help?
Thanks.1 Reply
Here's some code that may be close enough for what you are
doing. The following delays for a number of clock cycles. You'll need to define the size of the instruction cache:
You can then base your delay routine on the configured cpu clock speed. For example:/* * dly_clks * * Instruction performance varies based on the core. For cores * with icache and static/dynamic branch prediction (II/f, II/s): * * Normal ALU (e.g. add, cmp, etc): 1 cycle * Branch (correctly predicted, taken): 2 cycles * Negative offset is predicted (II/s). * * For cores without icache and/or no branch prediction (II/e): * * Normal ALU (e.g. add, cmp, etc): 6 cycles * Branch (no prediction): 6 cycles * * For simplicity, if an instruction cache is implemented * assume II/f or II/s. Otherwise, assume the II/e. * */ .globl dly_clks dly_clks: # if (ICACHE_SIZE > 0) subi r4, r4, 3 /* 3 clocks/loop */# else subi r4, r4, 12 /* 12 clocks/loop */# endif bge r4, r0, dly_clks ret
Your mileage may vary based on your clock & cache config ;-) Regards, --Scottextern void dly_clks (unsigned long ticks); void udelay (unsigned long usec) { unsigned long cnt = (SYS_CLK_FREQ/1000000) * usec; dly_clks (cnt); }
