22 years agoHelp with us delay routine in C
Hi...I am trying to create an i2c engine in Nios to read and write to an external seeprom. The problem I am having is developing an accurate micro second delay routine for the protocol. I know the ...
22 years agoHere's some code that may be close enough for what you are
doing. The following delays for a number of clock cycles. You'll need to define the size of the instruction cache:/*
* dly_clks
* Instruction performance varies based on the core. For cores
* with icache and static/dynamic branch prediction (II/f, II/s):
* Normal ALU (e.g. add, cmp, etc): 1 cycle
* Branch (correctly predicted, taken): 2 cycles
* Negative offset is predicted (II/s).
* For cores without icache and/or no branch prediction (II/e):
* Normal ALU (e.g. add, cmp, etc): 6 cycles
* Branch (no prediction): 6 cycles
* For simplicity, if an instruction cache is implemented
* assume II/f or II/s. Otherwise, assume the II/e.
.globl dly_clks
dly_clks:
# if (ICACHE_SIZE > 0)
subi r4, r4, 3 /* 3 clocks/loop */# else
subi r4, r4, 12 /* 12 clocks/loop */# endif
bge r4, r0, dly_clks
ret You can then base your delay routine on the configured cpu clock speed. For example: extern void dly_clks (unsigned long ticks);
void udelay (unsigned long usec)
unsigned long cnt = (SYS_CLK_FREQ/1000000) * usec;
dly_clks (cnt);
} Your mileage may vary based on your clock & cache config ;-) Regards, --Scott
