20 years agoHelp with avalon Interval Timer
HI
I made a Project in qu@rtus II 5.0sp1 Web edition, and in SOPC Builder, I added NIOS II cpu, AvalonTri-State Bridge to an external SRAM, Jtag UART and a Interval Timer. The system generation and hardware configuration went fine. When did a simple application for the design in Nios II IDE Evaluation Edition 5.0, it alsow worked fine, although the aplication didn´t use the Interval Timer. So I want to try the Timer. I want to use the Intervall timer to mesure the time for som executions for example Sum = 5; So I want to initalize the timer, start it, then after the execution stop it and then read the value. For example like this : int main(Void) { int Sum = 0; int Time = 0; ........ // Here I want to initalize the timer ........ // Start the timer Sum = 5; ........ // Stop the timer Time = ........ // Read the value of the timer return 0; } Can someone give me an example C code. /MrZ3 Replies
Start looking at the documentation provided for the timer component. There you will find on what adresses you must write to initialse the timer, and to read it out.
I think you should have a look at the performance counter peripheral...
simpler still, you can just use the timestamp feature in the HAL. See the section "High Resolution Time Measurement" in the Nios II Software Developer's Manual for a description and a code example.
Remember to set the timestamp device to be your timer in the system library properties page in the Nios II IDE.
