19 years agoHelp me!Configure uCLinux kernel eeror in NiossII!
i want to embed uCLinux into NiosII soft cpu, and i have install the Microtronix uCLinux 1.4, but when i create a project in NiosII-ide, i can not configure kernel of uCLinux correctly(winXP), it has some errors that shows in following PIC, please help me!Thanks
NiosII6.1+Qii6.1 +Micro uCLinux1.4 http://www.dzkf.net/attachment.php?aid=7635&noupdate=yes¬humb=yes http://www.dzkf.net/attachment.php?aid=7634&noupdate=yes¬humb=yes eclipse.buildId=M20060629-1905 java.version=1.5.0_06 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN Command-line arguments: -data D:\altera_proj\nios2linux\nios2_C35\workspace -os win32 -ws win32 -arch x86 Error Mon Mar 26 14:26:32 CST 2007 An exception occurred while dispatching debug events. java.lang.NullPointerException at org.eclipse.cdt.launch.AbstractCLaunchDelegate.getProjectName(AbstractCLaunchDel egate.java:177) at org.eclipse.cdt.launch.AbstractCLaunchDelegate.getCProject(AbstractCLaunchDelega te.java:162) at com.altera.nj.launch.internal.ui.LaunchUIPlugin.handleDebugEvents(LaunchUIPlugin .java:243) at org.eclipse.debug.core.DebugPlugin$EventNotifier.run(DebugPlugin.java:1076) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37) at org.eclipse.debug.core.DebugPlugin$EventNotifier.dispatch(DebugPlugin.java:1108) at org.eclipse.debug.core.DebugPlugin$EventDispatchJob.run(DebugPlugin.java:344) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58) eclipse.buildId=M20060629-1905 java.version=1.5.0_06 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN Command-line arguments: -data D:\altera_proj\nios2linux\nios2_C35\workspace -os win32 -ws win32 -arch x86 Error Mon Mar 26 14:26:32 CST 2007 Problems occurred when invoking code from plug-in: "org.eclipse.debug.core". java.lang.NullPointerException at org.eclipse.cdt.launch.AbstractCLaunchDelegate.getProjectName(AbstractCLaunchDel egate.java:177) at org.eclipse.cdt.launch.AbstractCLaunchDelegate.getCProject(AbstractCLaunchDelega te.java:162) at com.altera.nj.launch.internal.ui.LaunchUIPlugin.handleDebugEvents(LaunchUIPlugin .java:243) at org.eclipse.debug.core.DebugPlugin$EventNotifier.run(DebugPlugin.java:1076) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37) at org.eclipse.debug.core.DebugPlugin$EventNotifier.dispatch(DebugPlugin.java:1108) at org.eclipse.debug.core.DebugPlugin$EventDispatchJob.run(DebugPlugin.java:344) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)2 Replies
the Microtronix plugin is designed to work with Quartus5.0, to get it working with 6.0 or 6.1 the pathes in the configure.bat file must be changed to point to Quartus6.1.
I only tried 6.0 so far because I have not yet upgraded to 6.1. In 6.1 the path structure has changed significantly, so it could be more effort to get it running on 6.1. Anyway I have changed to build projects on a Linux host in the meantime because the Cygwin environment does not support initramfs - Altera_Forum
thanks!
i have accomplished the work in Nios6.0, but i think i should do more work in the linux OS. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
