19 years agoHelp me!Configure uCLinux kernel eeror in NiossII!
i want to embed uCLinux into NiosII soft cpu, and i have install the Microtronix uCLinux 1.4, but when i create a project in NiosII-ide, i can not configure kernel of uCLinux correctly(winXP), it has...
19 years agothe Microtronix plugin is designed to work with Quartus5.0, to get it working with 6.0 or 6.1 the pathes in the configure.bat file must be changed to point to Quartus6.1.
I only tried 6.0 so far because I have not yet upgraded to 6.1. In 6.1 the path structure has changed significantly, so it could be more effort to get it running on 6.1. Anyway I have changed to build projects on a Linux host in the meantime because the Cygwin environment does not support initramfs
