20 years agoHelp! Error occurs when I use PLL in NiosII
The error as follow:
Error: Clock input port inclk[0] of PLL "niosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|pll" must be driven by a non-inverted input clock pin But I didn't invert the clock before the PLL input clock pin. How can I slove the problem? Will anyone help me? Thanks in advance!1 Reply
I believe you have to use a dedicated input clock pin to drive a PLL. The message isn't referring to what you've done, internally (logic-wise), but that you're trying to drive a PLL with an incorrect incoming pin.
- slacker
