20 years ago
help about usb(isp1362)....
I add ISP1362 into the kerne follow this website:
(//something i did different with the website :
1. I did it with de2 board,frist I sclect the "Altera Cyclone Development board support",but I got the same result with "Microtronix Cyclone Development board support",so i think it's no effect.
2. I can't use "de2 "board selected,which only did the "U30(epcs) and U20(cfi flah) and with "The folder contains a system directory and a netlist directory which are empty". so I selectde the "cyclone_2c35".)
I don't know these tow is cause my wrong result.
but in other project without USB ,which I did like this ,I didn't got wrong result, so i think is is not the reason of the wrong result.
http://www.8ung.at/nacide_manfred/linuxtut...sp1362usbdriver (http://www.8ung.at/nacide_manfred/linuxtutorial.html#isp1362usbdriver)
compile successfully,but though the terminal,I got this messgae :
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 003F0000
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6148k/8192k RAM, 0k/0k ROM (1606k kernel code, 318k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NIOS serial driver version 0.0
ttyS0 (irq = 2) is a builtin NIOS UART
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x806810e0 (irq = 0) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 8 RAM disks of 4096K size 1024 blocksize
dmfe_probe:eth0, 50000 Khz Nios
<DM9000A> eth0 I/O: 806810f0, VID: 90000a46
ADDR: 00:07:ed:00:00:00
dmfe_probe:eth1, 50000 Khz Nios
scsi_debug_init: out of memory, 1
Microtronix map: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Microtronix development partition definition
Creating 2 MTD partitions on "Microtronix map":
0x00200000-0x00400000 : "romfs"
0x00000000-0x00200000 : "loader/kernel"
driver isp1362-hcd, 2006-04-28
datastart=806810d0,dataend=806810d3,adrstart=806810d4,adrend=806810d7,irq=6
ISP1362 Host Controller, irq 6
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
chipID=3630
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100
isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200
isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680
isp1362-hcd isp1362-hcd: USED/FREE: 3968 128
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 0 ports detected // this is different with the "right"which is "hub 1-0:1.0:2 ports detdcted.
//then boot stopped like dead, it different with the "right":
datastart=80900080,dataend=80900083,adrstart=80900084,adrend=80900087,irq=4
ISP1362 Host Controller, irq 4
chipID=3630
usb usb1: Product: ISP1362 Host Controller
usb usb1: Manufacturer: uClinux 2.6.11-uc0 isp1362-hcd
usb usb1: SerialNumber: isp1362-hcd
hub 1-0:1.0: 2 ports detected //here is different with the result i goted
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
/cygdrive/d/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.
kernel_1.4.0/linux-2.6.x/drivers/usb/input/hid-core.c: v2.0:USB HID core driver
// i don&#39;t know what&#39;s wrong with it ,who could help me solve this problem.thanks!!
thanks!!!
1 Reply
    --- Quote Start ---
    originally posted by lameck@Aug 19 2006, 09:50 AM
    i add isp1362 into the kerne follow this website:
    (//something I did different with the website :[/b]
    1. I did it with de2 board,frist I sclect the "Altera Cyclone Development board support",but I got the same result with "Microtronix Cyclone Development board support",so i think it&#39;s no effect.
    2. I can&#39;t use "de2 "board selected,which only did the "U30(epcs) and U20(cfi flah) and with "The folder contains a system directory and a netlist directory which are empty". so I selectde the "cyclone_2c35".)
    I don&#39;t know these tow is cause my wrong result.
    but in other project without USB ,which I did like this ,I didn&#39;t got wrong result, so i think is is not the reason of the wrong result.
    uClinux/Nios II
    Built 1 zonelists
    chipID=3630
    chipID=3630
    thanks!!!
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17714)
    --- Quote End ---
    [/b]
    --- Quote End ---
