20 years agohelp about usb(isp1362)....
I add ISP1362 into the kerne follow this website: (//something i did different with the website : 1. I did it with de2 board,frist I sclect the "Altera Cyclone Development board support",but...
20 years ago --- Quote Start --- originally posted by lameck@Aug 19 2006, 09:50 AM i add isp1362 into the kerne follow this website:
(//something I did different with the website :[/b] 1. I did it with de2 board,frist I sclect the "Altera Cyclone Development board support",but I got the same result with "Microtronix Cyclone Development board support",so i think it's no effect. 2. I can't use "de2 "board selected,which only did the "U30(epcs) and U20(cfi flah) and with "The folder contains a system directory and a netlist directory which are empty". so I selectde the "cyclone_2c35".) I don't know these tow is cause my wrong result. but in other project without USB ,which I did like this ,I didn't got wrong result, so i think is is not the reason of the wrong result. ) http://www.8ung.at/nacide_manfred/linuxtut...sp1362usbdriver (http://www.8ung.at/nacide_manfred/linuxtutorial.html#isp1362usbdriver) compile successfully,but though the terminal,I got this messgae : uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 003F0000 Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6148k/8192k RAM, 0k/0k ROM (1606k kernel code, 318k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub NIOS serial driver version 0.0 ttyS0 (irq = 2) is a builtin NIOS UART Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x806810e0 (irq = 0) is a jtag_uart io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 8 RAM disks of 4096K size 1024 blocksize dmfe_probe:eth0, 50000 Khz Nios <DM9000A> eth0 I/O: 806810f0, VID: 90000a46 ADDR: 00:07:ed:00:00:00 dmfe_probe:eth1, 50000 Khz Nios scsi_debug_init: out of memory, 1 Microtronix map: Found 1 x16 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Microtronix development partition definition Creating 2 MTD partitions on "Microtronix map": 0x00200000-0x00400000 : "romfs" 0x00000000-0x00200000 : "loader/kernel" driver isp1362-hcd, 2006-04-28 datastart=806810d0,dataend=806810d3,adrstart=806810d4,adrend=806810d7,irq=6 ISP1362 Host Controller, irq 6 isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 chipID=3630 isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 hub 1-0:1.0: USB hub found hub 1-0:1.0: 0 ports detected // this is different with the "right"which is "hub 1-0:1.0:2 ports detdcted. //then boot stopped like dead, it different with the "right": .......... driver isp1362-hcd, 2006-04-28 datastart=80900080,dataend=80900083,adrstart=80900084,adrend=80900087,irq=4 ISP1362 Host Controller, irq 4 isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 chipID=3630 isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: Product: ISP1362 Host Controller usb usb1: Manufacturer: uClinux 2.6.11-uc0 isp1362-hcd usb usb1: SerialNumber: isp1362-hcd hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected //here is different with the result i goted Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. usbcore: registered new driver hiddev usbcore: registered new driver usbhid /cygdrive/d/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux. kernel_1.4.0/linux-2.6.x/drivers/usb/input/hid-core.c: v2.0:USB HID core driver ... // i don't know what's wrong with it ,who could help me solve this problem.thanks!!
thanks!!! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17714) --- Quote End --- [/b] --- Quote End ---
