HAL API for the Generic Serial Flash Interface FPGA IP, 'altera_safeclib'
- 4 years ago
Hi Meenalkb,
To enable the Generic Serial Flash Interface (GSFI) use the HAL API and follow the below steps in Eclipse.
- BSP Editor->Nios II
- file paths of .sopcinfo and .bsp (new or old) in the open BSP window and click on open.
- A platform design window will be open in which you select the BSP software packages option. In that, just enable the altera_safeclib option.
- Select Generate BSP.
once the BSP generation is completed. Check in the drivers->inc and drivers->src folders. for
https://www.intel.com/content/www/us/en/docs/programmable/683419/22-1-20-1-1/nios-ii-hal-driver.html
- intel_generic_serial_flash_interface_top.h
- intel_generic_serial_flash_interface_top.c
Quartus 21.1.
also tested in Quartus 21.1. That option is available in Quartus 21.1. I think the problem is in software only. It's better to re-install or update the software.
- hareesh4 years ago
can you pls share your platform_design
- meenalkb4 years ago
Hi @hareesh ,
I've attached the .qsys and the .sopcinfo.
I don't know if this is relevant but the IP cores were originally from a Quartus Prime 18.1 design and have been upgraded by the tool to 21.1.
Thanks.- hareesh4 years ago
Hi, MEENAL BURROWS,
We have tried reproduce the issue with your shared files but we couldn't reproduce it. There no issue in our environment. Attaching a snapshot of project where you can see the option is available in our environment. we require remote access of your machine to debug this issue further
Thanks & regards,
Hareesh B
