TonyH
4 years agoHAL API for the Generic Serial Flash Interface FPGA IP, 'altera_safeclib'
In the user guide for the Generic Serial Flash Interface (GSFI) it says "altera_safeclib" must be enabled in the BSP editor to use the HAL API for this device.
With a Quartus 21.1 install and the a...
AEvers
4 years agoI'm currently facing the same issue. I added a "Generic Serial Flash Interface" IP Core to my NIOS Design. The Flash is working correctly when using the direct IOWR and IORD, but the API commands are not working. In the manual it says
- Enable altera_safeclib in BSP Software Package from BSP Editor to use the HAL API.
But in on the BSP Software Package Page of my BSP Editor there is no altera_safeclib.
Do I have to do a setting somewhere to get the altera_safeclib in the BSP Editor?
@TonyH Did you solved the issue in your design?
meenalkb
4 years agoHello,
Any luck resolving this? I am seeing the same problem. Could @EBERLAZARE_I_Intel or @KennyTan_Altera please provide some help?
Cheers
