GPIO driver code.
Hi Deepag,
I will set this thread to close pending since the original GPIO driver code issue been addressed. Do check on the Arria 10 user guide for the ethernet part and also our design store that contains several ethernet design to see whether it helps in your ethernet implementation. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you if any issues on the GPIO side. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
If there is further issues on ethernet documents/implementation, please do not hesitate and create a new forum/IPS case for it and we will attend to it shortly.
Kian
