Generating Flash Programming file using sof2flash
- 1 year ago
Hi Shaul,
From the sof2flash description, it will generate a s-record/srec file output
I saw that is one KDB on converting , but I'm not sure whether it supports your flash size density , but you can try if needed and change the EPCQ.
https://www.intel.com/content/www/us/en/support/programmable/articles/000077309.html
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/nios2-elf-objcopy.html
Alternatively I was talking to our engineering, since niosII is obsolete and removed from newer Quartus Pro version, tools such as sof2flash & nios2-elf-objcopy also been removed , the recommended approach for programming SOF into QSPI is to use JIC file instead.
Kian
Hi Shaul,
Thanks for contacting Intel Support Forums. I'm Kian and will be assisting in this case.
Please do allow me some time to check on the sof2flash and will revert back to you.
Kian
