XintingXue
3 years agoGenerating BSP has encountered a problem
Hello all, I was trying to measure the code execution time inside of the Nios II, thus an "interval timer" peripheral could be necessary to do this. Therefore, I recently added an "interval timer" i...
EBERLAZARE_I_Intel
3 years agoHi,
Can you quick share your design or .sopcinfo I will to replicate from my side.
Did you have a run test previously where it runs OK? Or any design will always turns this error?
- XintingXue3 years ago
Many thanks for your reply.
I encountered this issue just after adding the new module "interval timer" into Nios II system.
The previous design (without adding any new modules) was an existing project and it runs OK. I will upload both .sopcinfo files. The old one is the design without any issues, and the current one is the design which encounters issues.
Please see attached.
