19 years ago
gdb-server can't find Cyclone II board
I'm trying to connect to a Cyclone II board using jtagd and nios2-gdb-server-wrapped under Linux.
They seem to find the USBBlaster OK -- the blue LED flashes briefly when I start the gdb-server, but then the gdb-server complains and exits:
# ./nios2-gdb-server-wrapped
There are no Nios II CPUs with debug modules available which match the values
specified.  Please check that your PLD is correctly configured, downloading a
new SOF file if necessary.#
Questions:[list][*]In the message above to what does the phrase "the values specified" refer? I don't see where I specified any values.[*]What command line parameters or config file entries do I need to connect to a Cyclone II demo board? I don't have a .jtag.conf file, and I know the gdb-server tries to read ~/.jtag.conf. Neither did I specify a config file when I started jtagd.
[/list]
    --- Quote Start ---
    originally posted by grante+nov 1 2006, 01:15 pm--><div class='quotetop'>quote (grante @ nov 1 2006, 01:15 pm)</div>
    --- quote start ---
    <!--quotebegin-hippo@Oct 30 2006, 08:16 PM
    would you please add a page on nios wiki to describe how to setup the gdb server?
    that would be very helpful. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
    --- Quote End ---
    Done: http://nioswiki.jot.com/wikihome/linuxgdbserver (http://nioswiki.jot.com/wikihome/linuxgdbserver)
    I see that we&#39;re encouranged to "sign our work" on the Wiki, but I&#39;ve no clue what that means or how to do it.
    FWIW, my privilege problem was due to the fact that I forgot to make /etc/hotplug/usb/usbblaster executable. Making jtagd suid root didn&#39;t work because suid executables ignore the LD_LIBRARY_PATH environment variable.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19059)</div>
    [/b]
    --- Quote End ---
    Thanks. It looks great.
    I don&#39;t understand what they mean by "sign your work", too.
