20 years agoFPGA programming Problem
Hello
This is not a really Nios problem but an FPGA problem. I have the Nios II development Kit with the cyclone II. I want to write a very small and easy VHDL code example to test the Development tools. My VHLD code has a single process which is sensitive on the clock and if the input is 1 the output gets one to. I connect the clock to the Pin_N2 the input to the Pin_Y11 (button) and the output to the Pin_W11 (led) after progamming this simple test on the board it wors very shortly and than rests again and loads the factory programmed programm out of the flash. Why does this happen. Should a process not be available for ever. Why does the bord resets? I hope you can help me thx flo3 Replies
I don't know cyclone II kit, but altera dev kits have a configuration epld
which is triggered by a special pin (pld_RECONFIGREQ_n) to reload the fpga. set this pin inactive in your design. also set unused pins = as inputs tristated in your design. - Altera_Forum
Thank you first
But i'm not sure how to set a pin inactive Do i have to set this pin to '0' in my module? Or can i do this in some quartus settings? mfg flo - Altera_Forum
pld_RECONFIGREQ_n (active low) seems to have a pullup,
so it should be sufficient to set "unused pins = as inputs tristated" in quartus assignement->settings->device->device%pin options ->unused pin. you can additional make an output pin pld_RECONFIGREQ_n and connect it to VCC in your top schematic.
