13 years agoFP Custom Instructions - exp() won't get any faster
Hi everybody. I'm working on a design using Nios II/f that heavily relies on floating point math. In Qsys I addedd Floating Point Hardware and I connected it to the Custom Instruction Master of ...
13 years agoI have a same trouble with divide in Floating Point Hardware. But i don't known why,too. :cry:
Hardware divide is enabled both in the Floating Point Hardware module and in the Nios II/f. And i sure divide avalible in Floating Point Hardware because i compare total logic elements in 2 cases (turn on/off dividion Floating Point Hardware): Turn on: 9724 LEs Turn off: 5041 LEs i sure Floating Point Hardware is used because it work with multiply float. Who is resolved it? Can you help me?
