19 years agoFlash programmer problem
I try to work with the flash programmer on my custom board
At the SOPC builder (board description) I describe my board, only the FLASH tab (I didn’t enter netlist), when I open the flash programmer it give me the error "the target board description was not found check the target board selection in SOPC builder for this system". Do any one know what is my problem ?? More details: The Jtag chain work fine (the flash programmer "target connection" detect it). I work with SOPC builder 6.0 and Qurtus II 6.0 I work with cyclone II. Thanks Gil7 Replies
For each Flash component in sopc builder (EPCS or CFI) you have to specify which of the flash chips from the board description it is. Open the flash component in sopc and select a chip.
IzI - Altera_Forum
Thank you for your response, but I try it and it is not the problem.
The compilation went well. But when the flash programmer read the ptf file it looks like it have some problem with the board description. - Altera_Forum
This is a workig generic (without netlist ...) board description (class.ptf) for a Cyclone II chip with both the EPCS and a CFI flash present. Compare it with yours.
CLASS ecs8_board { BOARD_DEFAULTS { class = "ecs8_board"; class_version = "1.0"; device_family = "CYCLONEII"; altera_avalon_epcs_flash_controller { reference_designators = "flash_serial"; } altera_avalon_cfi_flash { reference_designators = "flash_parallel"; } reference_designators = "flash_parallel,flash_serial"; initial_system_file = ""; CONFIGURATION hardware_image { reference_designator = "flash_serial"; offset = "0x00000000"; menu_position = "0"; } } USER_INTERFACE { USER_LABELS { name = "ecs8_board"; } WIZARD_UI bind { PINASSIGNER { java = "com.altera.pinassigner.ui.SopcPinAssigner"; } } } SOPC_Builder_Version = "6.00"; NETLIST { NETLIST_INFO { IGNORE { net = "(VCC|GND).*"; device = "C+"; } PIN_CONNECTION_TYPE Rnnn { ids = "R+"; CONNECT { pin1 = "1"; pin2 = "2"; } } } } ASSOCIATED_FILES { Bind_Program = "bind"; } type = "board"; } - Altera_Forum
TO_BE_DONE
inside the .ptf file
inside MODULE your_epcs_controller_name {} check for the line (as it should look in your example):
but now I have no further ideas IzIflash_reference_designator = "U1"; - Altera_Forum
I checked it and unfortunately it is "U1" so it is not that ...
thank you anyway Gil - Altera_Forum
You may try to Flash your board using programming scripts directly from the cygwin shell.
The script can be found in (since the script was probably not yet created for your project try one from the demo projects for the development board): ...\quartus_project\software\software_project\Debug Modify the script and run it, if you do not know what command parameters mean do
You may omit checking of sysid or place --accept-bad-sysid in the scripts to avoid errors... But this might not solve the problem, try starting a new project from scratch: - start a new Quartus project with the same pinout definitions (they can be found in the .qsf file) - start a new sopc project - create a new board description from the sopc menu (the epcs flash can be called anything, U1 does not seem to appropriate) - select the board description - select only some essential components (cpu, memory, epcs, a timer) - generate the sopc project - in quartus connect SOPC IO signals with chip pins ... Be sure to use a slightly different name for the quartus project, sopc project and board description. Learn to compare source files, this is a list of source files for a simple hardware project, all other files are generated or copied from libraries. my_project.qpf (nothing useful, only project definition) my_project.qsf (specifies the chip, pinout, ... can usually be safely modified in a text editor) my_project.bdf or my_project.vhd (top level project source file) my_sopc_project.ptf (description of the SOPC builder component) /my_project_board/class.ptf (board description, did you check this?) IzInios2-flash-programmer --help
