19 years agoFlash programmer problem
I try to work with the flash programmer on my custom board At the SOPC builder (board description) I describe my board, only the FLASH tab (I didn’t enter netlist), when I open the flash programme...
19 years agoThis is a workig generic (without netlist ...) board description (class.ptf) for a Cyclone II chip with both the EPCS and a CFI flash present. Compare it with yours.
CLASS ecs8_board
BOARD_DEFAULTS
class = "ecs8_board";
class_version = "1.0";
device_family = "CYCLONEII";
altera_avalon_epcs_flash_controller
reference_designators = "flash_serial";
altera_avalon_cfi_flash
reference_designators = "flash_parallel";
reference_designators = "flash_parallel,flash_serial";
initial_system_file = "";
CONFIGURATION hardware_image
reference_designator = "flash_serial";
offset = "0x00000000";
menu_position = "0";
USER_INTERFACE
USER_LABELS
name = "ecs8_board";
WIZARD_UI bind
PINASSIGNER
java = "com.altera.pinassigner.ui.SopcPinAssigner";
SOPC_Builder_Version = "6.00";
NETLIST
NETLIST_INFO
IGNORE
net = "(VCC|GND).*";
device = "C+";
PIN_CONNECTION_TYPE Rnnn
ids = "R+";
CONNECT
pin1 = "1";
pin2 = "2";
ASSOCIATED_FILES
Bind_Program = "bind";
type = "board";
