16 years agoExtrem Guide to Kill Neek with u-boot : Kernel panic.
Hi, I am following the nios wiki (Extrem guide to kill neek with u-boot) I notice a mistake in the tutorial when we send neek.bin. More precisely, the zone to "deprotect" and to erase si not ...
16 years agoI have once more problems in the Extrem guide. Always at the same step (MTD and JFFS2).
Now just after make menuconfig appears questions about the user space, the uClinux distribution configuration. So i suppose that the config.linux-2.6.x is correct new (because i don't have the previous question about the kernel configuration anymore) but i suppose that config.vendor-2.6.x is incorrect. (When i use the other config.vendor-2.6.x in nios2 dir, no question about configuration appears but when i use yours, there are questions) And if i use the config.vendor-2.6.x of nios2 dir in the neek dir, so i can build uClinux-dist, an error occurs in the compilation : cp: ne peut évaluer `../common/nsswitch.conf': Aucun fichier ou répertoire de ce type make[2]: *** [romfs] Erreur 1 make[2]: quittant le répertoire « /home/Adrien/nios2-linux_MMU/nios2-linux/uClinux-dist/vendors/Altera/neek » make[1]: *** [romfs] Erreur 2 make[1]: quittant le répertoire « /home/Adrien/nios2-linux_MMU/nios2-linux/uClinux-dist/vendors » make: *** [romfs.subdirs] Erreur 1
