Ethernet performance using TSE in uClinux
Hi all,
I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and barely get up to 12Mbit/s. I did some timings using UDP and a 1024 byte message using a bind()ed and connect()ed socket: Total time to send message (when sendto() or write() is called until it returns): 650us Time spent in the driver (using atse.c driver, altera_tse.c driver gives similar performance): 140us Time in the driver waiting for the hardware to send data: 80us (seems it's doing 100Mbit instead of GbE, but that's a relatively small issue here considering overall performance) Kernel overhead before entering driver code: ~400us Kernel overhead after exiting driver code: ~100us Timing was done by writing to an output pin and using an osciloscope. It seems there's just a lot of overhead using the linux IP stack on the Nios II. Has anybody been able to get better performance or is it hopeless given the speed of the processor?55 Replies
--- Quote Start --- That is, of course, if the TSE does not already implement it in hardware. --- Quote End --- Altera's TSE has hardware CRC generators. Please check the datasheet. http://www.altera.co.jp/support/ip/interface-protocols/ips-inp-tse.html Almost all MAC have hardware CRC generators, because they need real-time CRC generation. Ethernet has CSMA/CD functions, so when the collision occurs, the MAC must add 'JAM' data which does'nt match the CRC. In ancient period, this task was too hard for those CPUs, so MAC has its CRC generator by historical reasons. About IP or UDP, they also have their checksum, but those are 16bit one's complement sum, not CRC. This is done by software, and in uClinux, the code is '/home/***/nios2-linux/linux-2.6/include/asm-nios2/checksum.h'. For IP packets, these checksum are done only for their headers. For UDP packets, the checksum is applied for whole data include their headers, and this eats CPU power, but it is optional. For the question of ' Ethernet performance using TSE in uClinux', please see the directory of '/home/***/nios2-linux/linux-2.6/net/ipv4', and feel how many things Nios CPU must do to send only 'ONE' UDP packet. Kazu - Altera_Forum
OK. Then it was either an exercise in futility, or and educational exercise on my part. Whatever it was, I was just trying to help. :)
--- Quote Start --- The Kernel Building configuration process ("make menuconfig" and friends) sets a lot of values in a configuration file that results in# define values (to be used by the Compiler) and other things (e.g. to be used in the linker script, but which I don't have much clue of yet). --- Quote End --- I know about the header with memory addresses and all, but I still can't find any auto-generated linker script. There is only the static one that comes with elf2flt that defines only one flat memory area, and another static one at linux-2.6/arch/nios2/kernel/vmlinux.lds.S that doesn't list a MEMORY. So how does the uClinux linker know where to put everything? Does it just grow from 0 and if it reaches out of main RAM you're screwed? - Altera_Forum
I feel that this is an important issue.
You might want to ask this in the uClinux and/or uClinux-NIOS mailing lists, where all the experts will listen -Michael - Altera_Forum
The other problem I'm having trying to implement this is that the SSRAM seems to be used for something already. There is data there, and if I try to write to it, whether it's the buffer or running a program that uses code with its text section there (I tried modifying vmlinux.lds.S), the system freezes. As far as I can tell the hardware doesn't use the SSRAM for anything and I haven't previously modified uClinux to use it in any way.
I suppose you need to define another TCM in your hardware design for this use.
I'm not sure what you mean. There is already a memory block for SSRAM in sopc builder and writing to some random addresses there works, but there is something there and I don't know where it's coming from and overwriting any significant amount of data there freezes the system.
#define na_ssram 0x05000000 # define na_ssram_size 0x00400000 # define na_ssram_end 0x05400000 # define na_ssram_clock_freq 100000000 - Altera_Forum
I suppose the system uses DRAM for normal purposes. So I, too, have no idea what the SSRAM might be used for.
I suggested TCM (internal RAM in the FPGA that does not use the Cache and the Avalon bus), as same would give the best possible performance. -Michael - Altera_Forum
--- Quote Start --- I know about the header with memory addresses and all, but I still can't find any auto-generated linker script. There is only the static one that comes with elf2flt that defines only one flat memory area, and another static one at linux-2.6/arch/nios2/kernel/vmlinux.lds.S that doesn't list a MEMORY. So how does the uClinux linker know where to put everything? Does it just grow from 0 and if it reaches out of main RAM you're screwed? --- Quote End --- The linker uses the script 'home/***/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/kernel/vmlinux.lds' and this script is generated from '/home/***/nios2-linux/linux-2.6/arch/nios2/kernel/vmlinux.lds.S', etc. The generator is '/home/***/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/kernel/.vmlinux.lds.cmd' (hidden file), I think, and this generator is generated from... , I don't know ! But anyway, you can control the linker from 'vmlinux.lds.S' and 'vmlinux.lds.inc'. Also you can check the symbol's locations by a map file '/home/***/nios2-linux/uClinux-dist/linux-2.6.x/System.map'. Kazu - Altera_Forum
--- Quote Start --- The other problem I'm having trying to implement this is that the SSRAM seems to be used for something already. There is data there, and if I try to write to it, whether it's the buffer or running a program that uses code with its text section there (I tried modifying vmlinux.lds.S), the system freezes. As far as I can tell the hardware doesn't use the SSRAM for anything and I haven't previously modified uClinux to use it in any way. --- Quote End --- I forgot to mention this. Where did you locate the exception hook codes? In the file '/home/***/nios2-linux/linux-2.6/arch/nios2/kernel/head.S',
the code 'exc_hook' is copied to the new location. Kazu/* This is the default location for the exception * handler. Code in jump to our handler */ exc_hook: movia r24,inthandler jmp r24 1: /* * After flushing the instruction cache, we must flush the data * cache. */ movia r1,NIOS2_DCACHE_SIZE movi r2,NIOS2_DCACHE_LINE_SIZE data_flush: flushd 0(r1) sub r1,r1,r2 bgt r1,r0,data_flush # ifdef CONFIG_BREAK_ON_START break# endif //CONFIG_BREAK_ON_START # if defined(CPU_EXCEPT_ADDRESS_ASM) && (CPU_EXCEPT_ADDRESS_ASM != (LINUX_SDRAM_START + 0x20)) /* Copy an instruction sequence to put at the exception address */ movia r2,exc_hook movia r3,CPU_EXCEPT_ADDRESS_ASM ldw r1,0(r2) stw r1,0(r3) ldw r1,4(r2) stw r1,4(r3) ldw r1,8(r2) stw r1,8(r3) flushd 0(r3) flushd 4(r3) flushd 8(r3) flushi r3 addi r3,r3,4 flushi r3 addi r3,r3,4 flushi r3# endif
