17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoThe other problem I'm having trying to implement this is that the SSRAM seems to be used for something already. There is data there, and if I try to write to it, whether it's the buffer or running a program that uses code with its text section there (I tried modifying vmlinux.lds.S), the system freezes. As far as I can tell the hardware doesn't use the SSRAM for anything and I haven't previously modified uClinux to use it in any way.
