17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoI suppose the system uses DRAM for normal purposes. So I, too, have no idea what the SSRAM might be used for.
I suggested TCM (internal RAM in the FPGA that does not use the Cache and the Avalon bus), as same would give the best possible performance. -Michael
