20 years ago
eth0 device not found
I am running a uClinux kernel (2.6.16) from DDR2 SDRAM on an Altera Cyclone II DSP Board. I have a Microtronix USB/Ethernet daughter card connected.
I enabled the Davicom DM9000 ethernet and TCP support in my kernel configuration.
I am using a crossover ethernet cable to connect the board to a laptop. The LED on the ethernet daughter card does not light (indicates that there is no link) and the laptop does not recognize the ethernet connection ("Network cable unplugged") (firewalls are disabled).
I am able to ping the ethernet card from the Altera board in a local loopback.
I can change the ip address when referencing "lo" (What is lo?) but recieve errors ("no such device") when referencing "eth0".
The following is bootup and the commands i have tried:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
/> Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.16-uc0 (dani@localhost) (gcc version 3.4.6)# 22 PREEMPT Tue Se
p 5 15:54:45 Local time zone must be set--see
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 00FF0000
Built 1 zonelists
Kernel command line:
PID hash table entries: 2048 (order: 11, 32768 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory available: 258048k/262144k RAM, 0k/0k ROM (1182k kernel code, 331k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80001200 (irq = 2) is a jtag_uart
dmfe_probe:eth0, 100000 Khz Nios
dmfe_probe: eth0 VID: 0x2B2A2928 .ne. 0x90000A46
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 224k freed (0x10136000 - 0x1016d000)
Shell invoked to run file: /etc/rc
Command: hostname uClinux
Command: mount -t proc proc /proc
Command: mount -t sysfs sysfs /sys
Command: mount -t usbfs none /proc/bus/usb
mount failed: No such file or directory
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/ (http://www.uclinux.org/)
Execution Finished, Exiting
Sash command shell (version 1.1.1)
/> ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif TX bytes:0 (0.0 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
/> ping 1270.0.1
ping: 1270.0.1: Unknown host
/> ping 127.0.0.1
127.0.0.1 is alive!
/> ifconfig eth0
ifconfig: eth0: error fetching interface information: Device not found
/> ls /mnt
/> ifconfig eth0 192.168.0.101
SIOCSIFADDR: No such device
/> ifconfig lo 192.168.0.101 netmask 255.255.255.0
/> ifconfig eth0 192.168.0.101 netmask 255.255.255.0
SIOCSIFNETMASK: No such device
/> ifconfig
inet addr:192.168.0.101 Mask:255.255.255.0
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:424 (424.0 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif TX bytes:424 (424.0 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif [/b]
--- Quote End ---
What have I missed? How can I connect to the Ethernet card?
    According to other posts and tutorials I have found, I have added DHCP support to my kernel. I also placed the DM9000 on a seperate tristate bridge in the SOPC builder.
    Still I have not been able to connect to the ethernet card...Anyone have any ideas???
    --- Quote Start ---
    originally posted by daniellew@Sep 7 2006, 07:55 AM
    according to other posts and tutorials i have found, i have added dhcp support to my kernel. i also placed the dm9000 on a seperate tristate bridge in the sopc builder.
    still i have not been able to connect to the ethernet card...anyone have any ideas???
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18134)
    --- quote end ---
    --- Quote End ---
    Maybe you have to add the correct ethernet drivers to the kernel. Someone similar happened to me before adding them. Yo have to go to kernel configuration, and then device drivers, Network device support. I don&#39;t know which eth driver will suit your eth device. Mine was Ethernet (10 or 100Mb) -> SMC 91111.
    aLeX
    I am using the Microtronix USB/Ethernet Daughter Board which has the DM9000 ethernet chip. So I have added Ethernet 10/100Mbit , Davicom DM9000 10_100 Ethernet chip support in my kernel.
    --EDIT--
    Although I have added the DM9000 support in my kernel I am not seeing the driver during bootup. Shouldn&#39;t I see it sometime in the boot script? Is there a step I&#39;m missing?
    --- Quote Start ---
    /> Uncompressing Linux... Uncompressing Linux... Ok, booting the kernel.
    Linux version 2.6.16-uc0 (dani@localhost) (gcc version 3.4.6)# 28 PREEMPT Thu Se
    p 7 12:36:12 Local time zone must be set--see
    uClinux/Nios II
    Built 1 zonelists
    Memory available: 258048k/262144k RAM, 0k/0k ROM (1197k kernel code, 341k data)
    shouldn’t there be a DM9000 driver or something that references DM9000 about here???
    TCP reno registered
    TCP bic registered
    Freeing unused kernel memory: 232k freed (0x1013a000 - 0x10173000)
    Welcome to
    ____ _ _
    / __| ||_|
    | | | | | | || | _ \| | | |\ \/ /
    |_|
    />[/b]
    --- Quote End ---
    --- Quote Start ---
    NET: Registered protocol family 2[/b]
    --- Quote End ---
    I think dmfe_probe has something to do with your DM9000 driver. In my system, I have smc_probe (which has to do with DM91111) and after:
     SMSC LAN91C111 DRIVER
     eth0: SMC91C11xFD (rev:1)
    So it seems that dmf_probe does not succeed looking for devices ... ¿?
    aLeX
