20 years agoeth0 device not found
I am running a uClinux kernel (2.6.16) from DDR2 SDRAM on an Altera Cyclone II DSP Board. I have a Microtronix USB/Ethernet daughter card connected. I enabled the Davicom DM9000 ethernet and T...
20 years agoI am using the Microtronix USB/Ethernet Daughter Board which has the DM9000 ethernet chip. So I have added Ethernet 10/100Mbit , Davicom DM9000 10_100 Ethernet chip support in my kernel.
--EDIT-- Although I have added the DM9000 support in my kernel I am not seeing the driver during bootup. Shouldn't I see it sometime in the boot script? Is there a step I'm missing? <div class='quotetop'>QUOTE </div> --- Quote Start --- /> Uncompressing Linux... Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.16-uc0 (dani@localhost) (gcc version 3.4.6)# 28 PREEMPT Thu Se p 7 12:36:12 Local time zone must be set--see uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 00FF0000 Built 1 zonelists Kernel command line: PID hash table entries: 2048 (order: 11, 32768 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory available: 258048k/262144k RAM, 0k/0k ROM (1197k kernel code, 341k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80001200 (irq = 2) is a jtag_uart shouldn’t there be a DM9000 driver or something that references DM9000 about here??? dmfe_probe:eth0, 100000 Khz Nios dmfe_probe: eth0 VID: 0x2B2A2928 .ne. 0x90000A46 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 4, 65536 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 17 Freeing unused kernel memory: 232k freed (0x1013a000 - 0x10173000) Shell invoked to run file: /etc/rc Command: hostname uClinux Command: mount -t proc proc /proc Command: mount -t sysfs sysfs /sys Command: mount -t usbfs none /proc/bus/usb mount failed: No such file or directory Command: mkdir /var/tmp Command: mkdir /var/log Command: mkdir /var/run Command: mkdir /var/lock Command: mkdir /var/empty Command: ifconfig lo 127.0.0.1 Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo Command: cat /etc/motd Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ (http://www.uclinux.org/) Execution Finished, Exiting Sash command shell (version 1.1.1) />[/b] --- Quote End ---
