20 years agoerrors about creating new component
I created a componet in sopc builder,the verilog HDL file is correct,because the code is the demo which on my board.But when generated,it show follow errors: <div class='quotetop'>QUOTE </div> --- Quote Start --- Altera SOPC Builder Version 5.10 Build 216 Copyright © 1999-2005 Altera Corporation. All rights reserved. # 2006.06.25 21:23:35 (*) mk_custom_sdk starting# 2006.06.25 21:23:35 (*) Reading project F:/TEST/audio_uclinux/DE2_SD_Card_Audio/nios_0.ptf.# 2006.06.25 21:23:36 (*) Finding all CPUs# 2006.06.25 21:23:36 (*) Finding all available components# 2006.06.25 21:23:36 (*) Reading F:/TEST/audio_uclinux/DE2_SD_Card_Audio/.sopc_builder/install.ptf# 2006.06.25 21:23:36 (*) Found 60 components# 2006.06.25 21:23:38 (*) Finding all peripherals# 2006.06.25 21:23:38 (*) Finding software components# 2006.06.25 21:23:41 (*) (Legacy SDK Generation Skipped)# 2006.06.25 21:23:41 (*) (All TCL Script Generation Skipped)# 2006.06.25 21:23:41 (*) (No Libraries Built)# 2006.06.25 21:23:41 (*) (Contents Generation Skipped)# 2006.06.25 21:23:41 (*) mk_custom_sdk finishing# 2006.06.25 21:23:41 (*) Starting generation for system: nios_0. .........................Can't use string ("") as a HASH ref while "strict refs" in use at e:/programe/altera/quartus51/sopc_builder/bin/ptf_parse.pm line 579. Error in processing. System NOT successfully generated.[/b] --- Quote End --- Help me please! Thanks a lot.2 Replies
Did you generate this custom component in a folder which contained spaces in the path?
--- Quote Start --- originally posted by zhengkaike@Jun 25 2006, 08:49 AM hi,i created a componet in sopc builder,the verilog hdl file is correct,because the code is the demo which on my board.but when generated,it show follow errors:
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
altera sopc builder version 5.10 build 216
copyright © 1999-2005 altera corporation. all rights reserved.
# 2006.06.25 21:23:35 (*) mk_custom_sdk starting# 2006.06.25 21:23:35 (*) reading project f:/test/audio_uclinux/de2_sd_card_audio/nios_0.ptf.# 2006.06.25 21:23:36 (*) finding all cpus# 2006.06.25 21:23:36 (*) finding all available components# 2006.06.25 21:23:36 (*) reading f:/test/audio_uclinux/de2_sd_card_audio/.sopc_builder/install.ptf# 2006.06.25 21:23:36 (*) found 60 components# 2006.06.25 21:23:38 (*) finding all peripherals# 2006.06.25 21:23:38 (*) finding software components# 2006.06.25 21:23:41 (*) (legacy sdk generation skipped)# 2006.06.25 21:23:41 (*) (all tcl script generation skipped)# 2006.06.25 21:23:41 (*) (no libraries built)# 2006.06.25 21:23:41 (*) (contents generation skipped)# 2006.06.25 21:23:41 (*) mk_custom_sdk finishing# 2006.06.25 21:23:41 (*) starting generation for system: nios_0.
.........................can't use string ("") as a hash ref while "strict refs" in use at e:/programe/altera/quartus51/sopc_builder/bin/ptf_parse.pm line 579.
error in processing. system not successfully generated. --- Quote End --- Help me please! Thanks a lot. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16391)</div> [/b] --- Quote End ---
I get exactly the same error message ....Can't use string ("") as a HASH ref while "strict refs" in use at C: ... I don't use spaces in path or file names. I can compile the project with the SOPC. But if I add or delete a component or if I rename a component I get this error message. Thanks a lot for help, beat
