16 years agoerror while run software in the target board
Hi
while i am trying to run my soft in the target board i have the following error in run configuration window
Actual system ID not found on target at base address
and that was my first project with nios 2 ide what i will do to solve this problem2 Replies
I had a similar problem a few minutes ago when creating a debug configuration. Though I forgotten to power-on my board, and hadn't downloaded the SOF file to the FPGA yet...
thank you
but i did that and the nios 2 ide see poth usb blaster and nios processor i don't believe that is the reason any why i solved the problem by tell the program to don't care about system id thank you any way
