16 years agoerror while run software in the target board
Hi while i am trying to run my soft in the target board i have the following error in run configuration window
Actual system ID not found on target at base address
and that was...
16 years agothank you
but i did that and the nios 2 ide see poth usb blaster and nios processor i don't believe that is the reason any why i solved the problem by tell the program to don't care about system id thank you any way
