20 years agoError while generating a uCLinux Kernel
I want to generate a uCLinux kernel for my microtronix cyclone dev board. But when generating i have this error message: ******************************************************************* /cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:262: error: `na_ide_ide' undeclared (first use in this function) /cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:262: error: (Each undeclared identifier is reported only once /cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:262: error: for each function it appears in.) /cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c: In function `init_ide_data': /cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:313: error: `na_ide_ide_irq' undeclared (first use in this function) make[3]: *** [drivers/ide/ide.o] Error 1 make[2]: *** [drivers/ide] Error 2 make[1]: *** [drivers] Error 2 make: *** [_all] Error 2 make: Leaving directory `/cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' ******************************************************************** I use a Nios II Ide V 5.0 ...when configuring the kernel i choose the cyclone microtronix board. I use a quartus design provided by microtronix.. But , when i choose an altera board when configuring the kernel, my kernel is well generated whitout errors !! ... But i have a microtronix board so i cant uopload it to board..... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif Thanks for helping me. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif2 Replies
It sounds like the Microtronix board default enables the CompactFlash interface, even though there isn't one in the design. You can turn this off by selecting:
Device Drivers --> ATA/ATAPI/MFM/RLL Support then clearing the checkbox. Tony - Altera_Forum
Thanks for the answer...
Device driver>>ATA/ATAPI/MFM/RLL support ( off ) driver>>Network support>>network suppor>> Ethernet(10 or 100 Mbits)>>SMC 91111 support (off) After that , i succed to generate succesfully my uCLinux Kernel for my microtronix board. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
