16 years agoError when download the linux image
can somebody tell me how to resolve it?
[NiosII EDS]$ nios2-download -g linux.initramfs.gz Exception: STATUS_ACCESS_VIOLATION at eip=00428ADE eax=00DA0214 ebx=00DA01C0 ecx=00DA01C0 edx=00000000 esi=00000000 edi=00000000 ebp=0022C758 esp=0022C720 program=c:\altera\81\nios2eds\bin\nios2-gnutools\H-i68 6-pc-cygwin\bin\nios2-elf-objcopy.exe, pid 4836, thread main cs=001B ds=0023 es=0023 fs=003B gs=0000 ss=0023 Stack trace: Frame Function Args 0022C758 00428ADE (00DA0214, 00000000, 00000001, 00000000) 0022C778 004205C3 (00DA01C0, 00000000, 43470000, 00DA2274) 0022C808 0043C352 (00DA01C0, 00DA09C0, 00000000, 00DA0290) 0022C828 0043535F (00DA01C0, 00DA09C0, 00000000, 61102A6F) 0022C898 0043BA61 (00DA01C0, 00000013, 00000001, 00000000) 0022C9E8 00438711 (00DA01C0, 00000000, 00000000, 00000000) 0022CA28 00423AF8 (00DA01C0, 00000001, 0022CA7C, 61022E25) 0022CAF8 00403A15 (00000000, 611B95B4, 004671D0, 00464180) 0022CCB8 00405429 (00000005, 611B9504, 00DA0090, 00000000) 0022CD68 61006108 (00000000, 0022CDA0, 61005450, 0022CDA0) 61005450 61004356 (0000009C, A02404C7, E8611151, FFFFFF48) 57E58955 EC815356 (00000000, 00000000, 00000000, 00000000) End of stack trace /cygdrive/c/altera/81/nios2eds/bin/nios2-download: line 492: 4836 Segmentation fault (core dumped) nios2-elf-objcopy $elffile -O srec $srecfile ./linux.initramfs.gz.srec: Unable to open input file rm: cannot remove `./linux.initramfs.gz.srec': No such file or directory3 Replies
I got the same error.
I copied the gz file to windows, and downloaded from windows environment. At least, it worked for me. - Altera_Forum
what do you mean the "windows environment"?
what did you download the file with? I downloaded the file with "nios II 8.1 command shell" It was in windows environment already. can you tell me something else in detail? --- Quote Start --- I got the same error. I copied the gz file to windows, and downloaded from windows environment. At least, it worked for me. --- Quote End --- - Altera_Forum
Ooops,
Sorry, it seems like you were on Windows... I saw same error on Linux, so I copied gz to Windows.
