15 years agoerror: no memory region specified for loadable section `.reset'
Hi, I met a error when I compile the example (in C) in the NiosII SBT. error: no memory region specified for loadable section `.reset' Do anybody know why this error appeared? I have specified ...
13 years agoThanx Jeffrey. I found a doc that talked about memory assignment and I added a mapping for '.reset' in the linker script. That seemed to take care of the issue. There is another problem though.. I am trying to implement the DE1_Basic _Computer. The projects builds and compiles. But only the red LEDs light up; the 7 Seg and the green LEDs don't work. I guess because the 8 second timer is not being incremented in the exception handling and interrupt service routines. I have tried to find the documents and PDFs relating to this but could not find a solution. Do you have a suggestion?
Thanks once again.
