15 years agoerror: no memory region specified for loadable section `.reset'
Hi, I met a error when I compile the example (in C) in the NiosII SBT. error: no memory region specified for loadable section `.reset' Do anybody know why this error appeared? I have specified ...
13 years ago --- Quote Start --- Hi, I met a error when I compile the example (in C) in the NiosII SBT. error: no memory region specified for loadable section `.reset' Do anybody know why this error appeared? I have specified the address of the reset vector in the SOPC builder and just trying to test the DE1_Media_Computer programs which are provided as reference designs. The strange thing is when I run small examples like getting_started_C or floating_C it works. But the error above appeared when running larger examples like interrupt_example_C or test_Media_Computer_C. Thank you in advance. Best, Dong --- Quote End --- Hi Dong! I realize this post is 2 years old. But I am having the same issue as you did. I have searched a lot on the forums but could not find a solution. How did you solve this problem? Regards, Ankur
