ERROR building simple NIOSV Compact project
- 1 year ago
Hi Barry,
Rather than Adding QSYS into project, please add QIP into the project. From 25.1std, the tool supports QIP only due to a change in Quartus compiler.
The tool also prompts with message below.
You may find a qip file located in the same folder of qsys system top level hdl file under project directory liking this.
Hope this is helpful.
Archer_Altera
Hi Frank,
Thanks and now i can see my NIOSV compact core appears to be building ! Many thanks for your help.
Can i ask if you know:
a) If there is a Tutorial guide /example design(s) from ALTERA for designing with and implementing the NIOSV core in an ALTERA FPGA ? I am using a MAX10 devices now but i will be using this processor with other ALTERA FPGAs in the near future.
b) Where is the location for the best documentation to which i can refer for using NIOSV cores in ALTERA FPGAs so that i can Bookmark the place ?
Barry
Hi Barry,
You may use link below as an entry to find more Nios V related document.
https://www.altera.com/design/guidance/nios-v-developer
Archer_Altera
