drbarryh's avatar
drbarryh
1 year ago
ERROR building simple NIOSV Compact project
Hello and greetings All Quartus + NIOSV experts, or indeed anybody who can help me fix this error !
I am trying to build a System Verilog design, based on Platform Designer, which uses a NIOSV compact IP core.
I am using Quartus Prime Version 25,1 Standard Edition on a Windows 10 Machine.
When trying to compile my test design i get these 2 errors :
Error (10170): Verilog HDL syntax error at niosv_cpp_fsm.sv(1418) near text: "'";  expecting ":", or "?", or binary operator. Check for and fix any syntax errors that appear immediately before or at the specified keyword. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error (10112): Ignored design unit "niosv_cpp_fsm" at niosv_cpp_fsm.sv(18) due to previous errors
Error 10112 is caused by previous error 10170. Does anybody have an idea why i get these errors ? I can't see the offending SV code because its encrypted (of course!). Is there a fix as well for this problem ?
Thanks for any help,
Dr Barry H
  • Hi Barry,
    Rather than Adding QSYS into project, please add QIP into the project. From 25.1std, the tool supports QIP only due to a change in Quartus compiler.
    The tool also prompts with message below.
    You may find a qip file located in the same folder of qsys system top level hdl file under project directory liking this.
    Hope this is helpful.
    Archer_Altera
  • Archer_Altera's avatar
    Archer_Altera
    Hi Barry,
    I can reproduce the issue you met on my side.
    This needs time for us to find the root cause. I will let you know when there is progress about this.
    Archer_Altera
    • drbarryh's avatar
      drbarryh
      Hi Archer_Altera, Thanks for your quick reply and analysis. Do you think it could be a tool installation problem ? Or a tool version issue ? Maybe other Standard editions don't have this problem ? I don't know yet because i have only managed to install the latest version of Standard edition.
      Barry
        Archer_Altera
        Hi Barry,
        Archer_Altera
