21 years ago
Error accessing memory address
Hello everyone!First ,I should thanks Fischer for give me advice .now I have a problem need someone's help.
the problem is :
The execution of program is suspended because of error.
Warning:
Cannot insert breakpoint 1.
Error accessing memory address 0x100034c: (undocumented errno -1).
Cannot insert breakpoint 3.
Error accessing memory address 0x1000358: (undocumented errno -1).
this problem appears whem I debug the software on my hardware.please do me a favor.Thank you very much!!!!!
    you should tell people a little more about your system
    - NIOS VERSION ?
    - QUARTUS VERSION ?
    - DEVELOPMENT BOARD ?
    is sample program running ?
    - CUSTOM BOARD ?
    - do you use external flash ,ram ?
    - is a NIOS sample program running ?
    - is a small testprogram runnning from onchip ram ?
    - does programming works ?
    - does a program from flash works ?
    My tools are:
    quartus4.2+niosII 1.1;stratix1s10 develop board;I make my own hardware image ,download it to stratix fpga, set up a software program,debug it in NIosII IDE.
    use external flash,sram,eternet,sdram and on_chip ram....;data memory and progrm memory is sdram,which base address is 0x0100000.
    In my program the function of printf can't work too.
    you ask that "is a small testprogram runnning from onchip ram ? ".
    I don't know .
    my program dosen't work.the program dosen't work from flash.
    "...I make my own hardware image ..."
    does the board work with a predefined hardware and software
    sample from altera ? could you debug, program such a sample ?
    I only know the cyclone board, but I think it should be the same,
    to check if your problem is perhaps the sdram, try to run
    - your program from sram,
    - a small testprogram fron onchip ram
    check the settings of your cpu in sopc builder.
    - reset address: flash
    - exception address: onchip memory (in my case)
    in system library set program and date memory to
    sram or onchipmemory.
