21 years agoError accessing memory address
Hello everyone!First ,I should thanks Fischer for give me advice .now I have a problem need someone's help. the problem is : The execution of program is suspended because of error. Wa...
21 years ago"...I make my own hardware image ..."
does the board work with a predefined hardware and software sample from altera ? could you debug, program such a sample ? I only know the cyclone board, but I think it should be the same, to check if your problem is perhaps the sdram, try to run - your program from sram, - a small testprogram fron onchip ram check the settings of your cpu in sopc builder. - reset address: flash - exception address: onchip memory (in my case) in system library set program and date memory to sram or onchipmemory.
