19 years agoErasing of Flash
When I use the following command:
system "nios2-flash-programmer --base=0x000000 --erase-all --cable=$cable --device=1 "; it starts erasing the flash. But it is sometimes it is ready wihtin 0.2 seconds and the flash is not erased at all. I'am using a cyclone device and a Intrel JS28F256 flash. Sometimes the erasing starts correctly and it takes much longer to erase the flash. Can someone help me??1 Reply
Two scenarios:
(1) If you are using an Altera built development kit, the flash memory signaling might have problem. I had experience with this before. (written successfully but couldn't load.) (2) If you build your own custom board, I wonder if you have other ways to confirm a stable flash I/O.
