19 years agoEPCS64N burn configuration problem
I am running with Quartus6.1 and Nios2 IDE6.1 with Nios2 StratixII Rohs board.
When I tried to burn FPGA configuration into Epcs64N with Nios2 IDE Flash Programmer, it said it can not find Epcs layout information: no Epcs-FF section. I read the old notes on this forum and Altera website and tried the solution with the override.txt file. Then the Flash Programmer pass through the verify, erase steps but when it tried to program the Epcs64N, it stops and shows the information below. Altera claims they have solved the No Lead problem on Epcs64N but they don't. Anybody has the same condition as me? I have been struggled with this for several days. Thanks, # !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd C:/altera/61/nios2eds/examples/verilog/niosII_stratixII_2s60_rohs/standard/so ftware/hello_led_0/Debug # Creating .flash file for the FPGA configuration "$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="$SOPC_KIT_NIOS2/examples/verilog /niosII_stratixII_2s60_rohs/standard/standard.sof" --output="standard.flash" Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=standa rd.opt C:/altera/61/nios2eds/examples/verilog/niosII_stratixII_2s60_rohs/standar d/standard.sof standard.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Allocated 120 megabytes of memory during processing Info: Processing ended: Thu Dec 07 09:27:15 2006 Info: Elapsed time: 00:00:08 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert standard.pof standard.rpd Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Allocated 50 megabytes of memory during processing Info: Processing ended: Thu Dec 07 09:27:20 2006 Info: Elapsed time: 00:00:04 # Programming flash with the FPGA configuration "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x01210800 --cable='U SB-Blaster [USB-0]' --sidp=0x012110D8 --id=1872630027 --timestamp=1165448106 "s tandard.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x012110D8: verified : Checksumming existing contents 00000000 : Verifying existing contents 00010000 : Verifying existing contents 00020000 : Verifying existing contents 00030000 : Verifying existing contents 00040000 : Verifying existing contents 00050000 : Verifying existing contents 00060000 : Verifying existing contents 00070000 : Verifying existing contents 00080000 : Verifying existing contents 00090000 : Verifying existing contents 000A0000 : Verifying existing contents 000B0000 : Verifying existing contents 00000000 : Reading existing contents 00010000 : Reading existing contents 00020000 : Reading existing contents 00030000 : Reading existing contents 00040000 : Reading existing contents 00050000 : Reading existing contents 00060000 : Reading existing contents 00070000 : Reading existing contents 00080000 : Reading existing contents 00090000 : Reading existing contents 000A0000 : Reading existing contents 000B0000 : Reading existing contents Checksummed/read 768kB in 18.5s 00000000 ( 0%): Erasing 00010000 ( 8%): Erasing 00020000 (16%): Erasing 00030000 (25%): Erasing 00040000 (33%): Erasing 00050000 (41%): Erasing 00060000 (50%): Erasing 00070000 (58%): Erasing 00080000 (66%): Erasing 00090000 (75%): Erasing 000A0000 (83%): Erasing 000B0000 (91%): Erasing Erased 768kB in 9.9s (77.5kB/s) 00000000 ( 0%): Programming Program failed Leaving target processor paused1 Reply
Hi Guys, there are not response but I think I found the resolution by myself.
1. Epcs64n is not supported on Nios IDE, you need the override.txt file. 2.Flash programmer doesn't work on FPGA configuration, you need to use Quartus to burn it. 3.You need NiosIDE to burn the Nios code. What a mess with the Altera works!
