19 years agoEPCS64N burn configuration problem
I am running with Quartus6.1 and Nios2 IDE6.1 with Nios2 StratixII Rohs board. When I tried to burn FPGA configuration into Epcs64N with Nios2 IDE Flash Programmer, it said it can not find Epcs la...
19 years agoHi Guys, there are not response but I think I found the resolution by myself.
1. Epcs64n is not supported on Nios IDE, you need the override.txt file. 2.Flash programmer doesn't work on FPGA configuration, you need to use Quartus to burn it. 3.You need NiosIDE to burn the Nios code. What a mess with the Altera works!
