epcs_signature_read_fail_error
Hi Sermaswathika,
I am sorry for the confused closing ticket last time. It is because you stated that JIC file programming is already working.
Regarding your question about this -
"the following configuration commands we have used for 13.1 design,
jtagconfig
nios2-configure-sof mem_check.sof
nios2-flash-programmer --epcs --base=0xA006000 mem_check.flash
nios2-flash-programmer --epcs --base=0xA006000 mem_check.jtag"
Quartus_pgm command method cannot be used here anymore as the tool nios2-flash-programme.exe is not supported. Thats why we only supporting the JIC file programming using the quartus programmer.
Is there anything else I can help?
Thank you.
- SERMASWATHIKA2 years ago
Contributor
Thanks for your confirmation . Because we have to inform to customer that flash file programming is obsolete..JIC file programming is the only option to program EPCQ . I will use jic file programming option.
Thank you.
