SERMASWATHIKA
Contributor
2 years agoepcs_signature_read_fail_error
Hi Team, when i tried to flash the FPGA with flash files using nios command shell, i am getting the following error, Please give solution for this.
SERMASWATHIKA
Contributor
2 years agohi ,
thanks for your response.
the reason for checking this is we are upgrading the design from 13.1 to 22.1 . In 13.1 design, we have used cyclone iii and now we are upgrading the device to cyclone v gx device in 22.1.
In 13.1 design , we have used flash file as programming files.
from what you have said, we cant use flash files as programming file as flash programmer is EOL.
So we need to adapt the jic file programming format.
is there any other way to use flash file format?
SERMASWATHIKA
Contributor
2 years agohi,
i have tried to generate .jic file also but i am getting error as address overlap
can you please give solution for this.
